Aug 22, 2016 12:37 PM UTC
Fatal error encountered.
jag skulle installera Creo i en annan dator med hjälp av en extand nätverkskort som jag använde för licens koden då fick jag det här meddelandet:
Fatal error encountered.  A treeceback has bieen written to
C: /Users / public / Documents / traceback.log
Please send it to Technical Support.
vad menas med det och vad kan jag göra?
Aug 23, 2016 1:09 PM UTC
I have to use translate.google.com to translate your responses to English language. Can you communicate in English, please ?
Note no.1
Your license file is related to USB network card (00-0A-CD-1D-C7-DB). Unfortunately this network card is not connected to network. Please connect it to enable Windows to assign IP adress to it. Then run ipconfig  /all again and publish its output.
Note no.2
Type of your license is floating. Did you install FLEXnet licence manager on your PC ?
MH
Aug 22, 2016 1:30 PM UTC
it is difficult to say what to do. Please publish output of ipconfig /all command and your license file.
MH
rtaleb1-VisitorAuthor
Aug 23, 2016 8:26 AM UTC
Hej Martin.
Tack för ditt svar.
Här är bilden för både nätverkskortet och licensekej.
Hälsningar.
Note no.1
Note no.2
MH
