3-Newcomer
flat pattern view for the drawing
Hi Team,
Greetings,
I am working on the code for drawing to add flat pattern view, please help me on this. Api/ code anything would be appreciated..
Thanks in advance
Abdul
This may not be exactky what you're looking for, but I Create a template files with the flat view already in it, then use toolkit to create a drawing using that template.  I have a templates for TOP, FRONT, AND RIGHT as the view of the flat that the user can select from.
If I need a flat view - I have a mapkey to create one, and then do other stuff - create or open a drawing and export it as dxf, etc.
Perhaps it is a solution for you.
3-Newcomer
map key again , we are diverting away from Programming..but i need through program.
