Foldder browser - workspace zoom issues
Is there a way to set the default zoom value when using the common files - workspace as i keep having to use the mouse wheel to zoom in/out.
TomU
According to CS31975, the answer seems to be no.
"Refreshing the embedded page discards the zooming and restores the default setting."
joe_morton
You could try changing your zoom setting for your computer. (That would apply everywhere, not just Creo).
Are you using a high definition monitor/laptop screen? We ran into this issue when we first started using HP laptops a few years ago that had really high resolution.
Solution/Workaround:
1.From Creo set the config.pro option, windows_browser_type to “chromium_browser”
2.Navigate to C:\Program Files\PTC\Creo 5.0.5.0\Parametric\bin, right click on “Parametric.exe”, Properties
3.From the Properties Compatibility tab, select Change high DPI settings
4.Check the box Override High DPI scaling behavior and set to “System”
