Oct 4, 2022 9:04 AM UTC
Format File parameter doesn't update/Show
I created an new Format file (.frm) and added there some parameters-links (via Note and &XXXX) with I want to automatically updated from the Main model parameters.
But when I load this Format to my drawing of the model the parameters do not update.
Anyone can give me a hint how to update the parameter-links in the format file according the 3D model parameters?
Oct 4, 2022 10:40 AM UTC
1.] you have to place a table into format
2.] you have to put &paramname into table cell
Oct 6, 2022 5:04 AM UTC
This worked!
Thanks a lot. But it's strange that this is not working inside a Note.
18-Opal
Oct 7, 2022 8:23 AM UTC
A SessionID or Component ID is required to link a component's parameter or dimension in a note.
See Article - CS20262 to see how.
Toolkit has ProSolidToPostfixId() to get the ID.
Regards, SeonHo CHA.
