Mar 19, 2021 6:40 PM UTC
Fraction dimension
Hello all,
I recently switched company's and in doing so I am learning Creo now.  I have used Inventor for many years before this.  I like a lot about the software and still have a few frustrations with the limitations that it has as well from what I am use to.  Which brings me to my question is there a way to set up the drawing template or a setting in the software so that my start our as fraction dimensions rather than decimal dimensions?  We use fractions for everything but machined parts.  So if gets a little frustrating to have to remember to highlight all the dimensions and turn them into fractions after I am done.  Thank you for the help.
tbraxton
tbraxtonAnswer
Mar 19, 2021 7:48 PM UTC
Familiarize yourself with these options.
Config options
dim_fraction_denominator 64    Change this value to the proper value for your process
create_fraction_dim yes
Drawing setup options
default_tolerance_mode NOMINAL
dim_fraction_format AISC
use_major_units YES
tbraxton
tbraxton22-Sapphire IIAnswer
Config options
use_major_units YES
Mar 19, 2021 7:55 PM UTC
thank you that worked!!!
Dale_Rosema
Mar 19, 2021 7:58 PM UTC
Don't forget to mark TBraxton's answer as correct for those who may search on this topic in the future.
