7-Bedrock
Apr 10, 2024 8:45 AM UTC
Get appearance properties of the Facetset/Facet objects using ProToolkit API's
I have CAD ( step/PVZ) models with parts which are composed of Facetset/Facet entities.
I want to export the geometry as well as material data for these parts.
I have got the API's to get the geometry data for them.
I did not find the API to get the material/appearance properties of these kind of objects.
There is one API ProSurfaceappearancepropsGet to get the appearance properties of the surface entities.
But I did not get the similar API for the Facetset/Facet entities.
Can anyone help me for this?
Emeritus
Apr 15, 2024 12:13 PM UTC
Hi psarode
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
psarode7-BedrockAuthor
7-Bedrock
May 6, 2024 7:06 AM UTC
Hi @achirila ,
Thanks for the suggestion but I have mentioned my scenario and got the answer from the PTC support also that whatever I was looking for is not possible with the current Toolkit API's. You can refer this Color information for Facetset/Facet using Toolkit API .
Also it would be very helpful if you mention what kind of more data you were expecting from me so that I will keep that in mind from next time?
