Jun 12, 2025 8:33 AM UTC
Get drawing information from model and than opening it using JS
We are experiencing difficulties opening drawings directly from the model . Currently, our designers have to manually go to the server information(Windchill), navigate to the content tab, find the drawing reference, and only then open the drawing.
Is there a way to use Creo JS to programmatically find the drawing reference associated with the current model in Windchill, and then automatically download and open it?
Any advice or example scripts would be greatly appreciated!
RPN
RPNAnswer
18-Opal
Jun 13, 2025 10:08 PM UTC
You don,t need to purches, there is Java API as well. I guess you can do that with a http request. The parent info is not written in the part, because of rename. If you do this via SQL you have to take permission or ACLs into account, so this may a long journey. If you have a rule <SolidName> equal to <DrawingName> then just try to open the Drawing. Don‘t forget to figure out the drawing, based on dependency types. just check the data in Windchill.
With external data you can write this to the solid as well, because renaming is most of the time due to numbering not allowed.
RPN
18-Opal
Jun 12, 2025 1:44 PM UTC
You need a SQL Query to figure out all related Drawings in Windchill.
Jun 13, 2025 6:04 AM UTC
Is this something we need to purchase separately, or is there free access available?
RPN
RPN18-OpalAnswer
18-Opal
