get left and bottom most edges from drawing view
Hi all.
In Creo toolkit how to take left and bottom most edges from the drawing view(not a model view)?
if anyone knows pls help me
CHASEONHOAnswer
18-Opal
1. Visit all views using ProDrawingViewVisit
2. Use ProDrawingViewSheetGet to determine the sheet number of the visited view
3. Compare positions using ProDrawingViewOutlineGet for the same sheet number
Below is sample code to get the bottom left view for recent sheets.
static int curSheet = -1;
ProError userViewVisit(ProDrawing drw,ProView view,ProError status,ProAppData data)
	int viewSheet = -1;
	status = ProDrawingViewSheetGet(drw,view,&viewSheet);
	if(curSheet == viewSheet)
		ProName viewName;
		status = ProViewNameGet(*(ProView*)data,viewName);
		if(status!=PRO_TK_NO_ERROR)	*(ProView*)data = view;
		else
			Pro3dPnt VeiwSize_1[2],VeiwSize_2[2];
			status = ProDrawingViewOutlineGet(drw,view,VeiwSize_1);
			status = ProDrawingViewOutlineGet(drw,*(ProView*)data,VeiwSize_2);
			if(VeiwSize_1[0][0] < VeiwSize_2[0][0] || VeiwSize_1[0][1] < VeiwSize_2[0][1])
	return PRO_TK_NO_ERROR;
ProError userTest()
	ProMdl drw;
	ProError status = ProMdlCurrentGet(&drw);
	if(status != PRO_TK_NO_ERROR)	return status;
	ProMdlType type;
	status = ProMdlTypeGet(drw,&type);
	if(type != PRO_MDL_DRAWING)	return PRO_TK_BAD_CONTEXT;
	status = ProDrawingCurrentSheetGet((ProDrawing)drw,&curSheet);
	ProView leftBottomView = NULL;
	status = ProDrawingViewVisit((ProDrawing)drw,(ProViewVisitAction)userViewVisit , NULL,&leftBottomView);
	if(leftBottomView != NULL)
		ProName viewName;
		status = ProViewNameGet(leftBottomView,viewName);
		ProMessageDisplay(MSGFIL,"USER %0ls",viewName);
Have a look at ProDrawingViewOutlineGet function.
Aravind9813-AquamarineAuthor
yes but with this i couldn't find the left most drawing view
RPN
18-Opal
What about to visit each view on a sheet and compare 🤪
CHASEONHO18-OpalAnswer
18-Opal
	int viewSheet = -1;
		ProName viewName;
		else
ProError userTest()
	ProMdl drw;
	ProMdlType type;
		ProName viewName;
RPN
18-Opal
What about this 😂
set xvalList [list]
foreach view [ps_view list] {
 ps_view outline $view outLineObj
 lappend xvalList [list $view [outLineObj cget -x1] ]
 lappend xvalList [list $view [outLineObj cget -x2] ]
set minItem [lindex [lsort -incr -index 1 $xvalList ] 0]
lassign $minItem ViewName xVal
Debug "The View $ViewName is topleft with x $xVal"
