Nov 5, 2014 1:04 PM UTC
Get parameter value using J-link
Hello!
I'm trying to get the value of a parameter, but it is returning this:
com.ptc.pfc.Implementation.pfcModelItem$Parameter@1187b50
I'm trying to get the parameter like this:
Parameter p;
p = (Parameter) model.GetParam("DESCRICAO");
txtDescricao.setText(p.toString());
This parameter exists in the model:
Could someone help me?
Thank you!
Nov 5, 2014 1:09 PM UTC
may be this is the ptc_common_name, this the model name, not an ordinary parameter.
This can be tested by changing the language setting of Creo (or Pro/E), if the parameter name change from DECRICAO to DESCRIPTION, then it is the ptc_common_name.
To access this parameter, you have to use the model name.
Nov 5, 2014 1:30 PM UTC
I am not using ptc_common_name parameter.
This parameter was created. It is not a common parameter.
The value of this parameter is manually entered.
Nov 5, 2014 2:02 PM UTC
Try this:
//assuming you already have a handel to a Creo model with String parameter "DESCRICAO"
Parameter param = model.GetParam("DESCRICAO");
ParamValue paramVal = param.GetValue();
String strParamVal = paramVal.GetStringValue();
txtDescricao.setText( strParamVal );
Nov 5, 2014 3:44 PM UTC
Thanks Tom Decock!
It worked as expected!
Nov 5, 2014 3:54 PM UTC
Hi Sulmaq,
Glad to help. Could you mark the answer as being correct ? Otherwise the status remains "not answered" 😉
