6-Contributor
Jun 1, 2018 9:39 PM UTC
getStringProperty not returning parameter name
When using JAVA API Class Fibre with inherited method "getStringProperty" is not returning the string
value that is set in the fiber artifact. This seems to be the correct method to use when trying to get the value of a parameter. I was using it to get the value of the obj_type parameter to see if the fiber is a wire or cable.
