Mar 3, 2018 6:20 AM UTC
Getting all the features of an assembly model using toolkit
Hello, I am new to using toolkit. I want to club all the cosmetic sketches from an assembly model into a new layer in its drawing. For that, I need to get all the features of the model. What is the API which enlists all the features of a model? Any help would be greatly appreciated. Thanks, Aniket
Mar 5, 2018 1:10 PM UTC
You can achieve it easily with Creo Toolkit API, but the hard part is you need to learn the basics first.
Creo toolkit reference and sample file available with Creo toolkit installation folder
Mar 6, 2018 4:09 AM UTC
Hi PK,
Thanks for your reply! I wanted to club all the cosmetic sketches in .asm file in a single layer. I am using the API ProSolidFeatVisit() to visit all the features and identify the cosmetic ones. However, the API only visits the features within that level. That is, if there are other .prt or .asm models within the parent model having the cosmetic features, they don't get identified. Is there a way we can visit all the features within all the levels?
Aniket
Mar 6, 2018 5:13 AM UTC
You can play with while, if and for loops
Use for loop to collect all the sub asm and part models & use while until the last child is part model then collect all cosmetics with id for all the part models.
This is the concept, you've to work on this. Just try
