May 24, 2016 9:30 AM UTC
Getting complete Feature information
Hey guys,
I'm trying to get a complete information about a feature(say extrude).
I've already got section(sketch) information. It wasn't hard at all.
Now I'm about to get properties of Extrude feature itself.
I mean these:
Is it extrusion from sketch to some distance, or extrusion between planes, or sketch is a center plane for extrusion, and so on and so forth.
I did read user Guide for Object Toolkit and it seems, necessary information is stored in a Future Element Tree(14. Feature Element Tree, 18. Features).
Now I got features elements and their values:
element id: PRO_E_FEATURE_TYPE
element value: 917
element id: PRO_E_EXT_SURF_CUT_SOLID_TYPE
element value: 917
The question is, am I correct? If I do need information about feature, should I use Feature Element Tree for that?
If yes, where can I find description for this element IDs? Cause it's not clear for me what is PRO_E_FEATURE_TYPE and what means 917 for this element. I parsed the User guide, headers and couldn't find any description
Thank you in advance,
Artem
FV_01
FV_01Answer
Jun 6, 2016 6:31 PM UTC
Hi all,
Artem,
You'll need to get a feature elemtree with ProFeatureElemtreeExtract(...) and then get a reference to sketch(section) plane by accessing PRO_E_STD_SECTION element and then PRO_E_STD_SEC_PLANE element. It will give you ProReference to a parent surface.
You should take a look at TestExtrude.c in pt_examples  it has everything you'll need...
HIH.
Feliks.
abursuk1-VisitorAuthor
Jun 2, 2016 11:53 AM UTC
Hey,
Using empirical method I figured out which elements are crucial to determine general feature parameters.
Only one thing is still not clear to me: How can I determine on whether plane my feature was initiated.
E.g. I have sketch(section) with rectangle there. Using extrude feature I will get a cube.
Nice, Now I want to create a lesser cube on a face of existing one. Done!
How can I get now the information about whether face was used to create sketch(section) for the lesser cube?
I can imagine only one opportunity to get geometrical info: take it from sketch, because all the curves on sketch will be placed in a single plane(sketch plane).
The final goal for me is to get point in sketch, but not the boundary ones(which I can get from the sketch).
Artem
FV_01
FV_0117-PeridotAnswer
Hi all,
Artem,
HIH.
Feliks.
Jun 8, 2016 12:11 PM UTC
Hi Feliks,
Thanks for the answer, it seems what I was looking for!
PS:
Maybe you happen to know which elements represent boundary surfaces for extrude? In case I want to perform extrude till surface\face ?
Artem
