Dec 9, 2017 9:25 AM UTC
HELP!!! J-LInk can't setup.
pro engineer 5.0  run on win7 under vmware.
i'm make sure j-link has been installed.
setup:
1. set working directory to <install path>\...\jlink\jlink_appls\install_test
2. click tools, select auxiliary applications.
3. select <install path>\...\jlink\jlink_appls\install_test\protk.dat
4. name is already in the list
5. select application item, click start, show 'setup of application "InsatllText" failed'
i'm no idea. and can't find any log file.
i'm online waiting for you
Dec 12, 2017 4:11 AM UTC
 thank for all replayer.
test j-link application has work after use jar
The test button appears in the list of file buttons after two steps:
use jar command create jar file from class file.
set 'javar_app_classpath' to protk.dat file.
Thank you for each response, and give me some ideas and methods.
thanks again.
I feel anxious about my English, too. thank translate
Dec 9, 2017 9:51 AM UTC
Hello, is anyone there?Hello, is anyone there?
2-Explorer
Dec 9, 2017 6:46 PM UTC
This is a user forum, not PTC technical support.
Most users are not at work and won't even see the message until Monday morning, starting in Europe.
Dec 11, 2017 1:58 AM UTC
So what you mean is that I should not ask this question
Dec 11, 2017 2:48 PM UTC
I suggest you to test old Java versions mentioned in http://support.ptc.com/WCMS/files/107703/en/J-LinkPlatformsWildfire50.pdf document.
Dec 11, 2017 2:58 PM UTC
thanks, I used the pro engineer 5.0 comes with jre to test
thank for u reply
Dec 11, 2017 3:18 PM UTC
what Wildfire 5.0 maintenance release do you use ? I mean Mxxx number. Maybe I will be able to run install_test tommorow.
anderson_zm1-VisitorAuthorAnswer
thanks again.
HamsterNL
18-Opal
Dec 12, 2017 6:59 AM UTC
I am glad you have got it working.
"Patience is a virtue"
Dec 13, 2017 2:19 AM UTC
thanks
