7-Bedrock
Hidden Lines appear as dashed blue geometry lines on model
Creo 10
It seems like when I display hidden lines some of them appear as blue dashed lines when they should appear as gray dashed lines.  Why is this occuring?  How can I fix this?
I have already tried editing the line style to Hidden and still they appear as blue dashed but when printing follow Geometry line style.  I can change the hidden line pentable settings and they only effect the gray dashed lines.
Below is the drawing in Creo: Blue dashed line and gray dashed lines are both hidden items in the view.
The gray hiddens lines appear correct when printing, but some of the hidden lines appear as blue dashed lines.  This is cuasing issues when printing.  The blue dashed lines follow the geometry pentable settings but as dashed lines.
Below is Print Preview - using pentable  - You can see the gray hidden lines appear correct and follow the pen table settings, while the blue dashed "hidden" lines follow the pentable settings of "geometry" only with the lines being dashed instead of solid.
please pack your data into single .zip file and upload it. This enable other users to investigate your problem.
