May 27, 2013 9:34 AM UTC
Hide and show parts
Hello All,
I would like to hide and show automatically the parts of a model using Pro/Toolkit. I don't want to have the user clicking to select them.
In fact I have an array of solids that are in my model : ProSolid* solidList; I can also have access to the asm component path of each part.
I saw the function ProModelitemUnhide and ProModelitemHide but, if I understood well, in order to use it I have to have the modelitem of my parts...
How do I get the modelitem of a part?
or
How can I hide/show parts?
Thank you
Emilie
8-Gravel
May 27, 2013 9:55 AM UTC
Hello!
Use the function ProMdlToModelitem to get a Modelitem from a Model.
May 27, 2013 9:58 AM UTC
Try:
ProMdlToModelitem((ProMdl)yourProSolid, theMItem)
and
ProModelitemHide(theMItem)
BR,
Etienne
Emilie1-VisitorAuthor
May 27, 2013 10:07 AM UTC
Oops, In fact I have solids :
here is what I do considering the fat that solid is a ProSolid I already have :
ProError err;
ProModelitem model_item;
err = ProMdlToModelitem(solid, &model_item);
if(err != PRO_TK_NO_ERROR)
printf("error %i in ProMdlToModelitem .\n",err);
else
err = ProModelitemHide(&model_item);
printf("error %i in ProModelitemHide.\n",err);
ProWindowRefresh (-1); //-1 pour current window
but then I get error -18 (means PRO_TK_INVALID_TYPE) in ProModelitemHide...
8-Gravel
May 27, 2013 10:23 AM UTC
try:
err = ProMdlToModelitem( ProSolidToMdl(solid), &model_item);
Jun 11, 2013 1:35 PM UTC
In case someone is interested in this :
Here is what I finally do :
I visit the displayed solids with ProSolidDispCompVisit.
In the ProSolidDispCompVisitAction I visit all the features of the solids that are an assembly with ProSolidFeatVisit. This will visit all the parts, assembly but also lines and I only want features that are assembly or parts so I use
ProAsmcompMdlGet(feature, &Mdl);
err = ProMdlTypeGet(Mdl, &MdlType);
in order to know what this feature is (thank you Lars 🙂 )
And then I can hide show this feature with
ProModelitemHide(feature)
and
ProModelitemUnhide(feature)
Emilie
Jul 18, 2018 8:41 AM UTC
HI,
I have a problem about the function ProModelitemHide
err=ProMdlToModelitem(asm_prt_data[i].prt_handle,&p_mdl_item_prt);
err=ProModelitemHide(&p_mdl_item_prt);
but the function ProModelitemHide STILL return 'PRO_TK_INVALID_TYPE'
i dont know how to slove it, is there anyone can help me?
Jul 18, 2018 8:59 AM UTC
I think here the problem is that only particular modelitems could  used to be hidden.
So you can convert a part to modelitem but I think the idea here is to be used for some parameter stuff - because it use a modelitem as input.
Here we need to take the component feature which contains the model and to hide it.
err=ProModelitemHide((ProModelitem *) &comp_feature);
So the question is how to get a component feature which corresponds to a model handle:
- you have visit the assembly  (ProSolidFeatVisit)and in the filter function you have to check for  (ProFeatType.h
PRO_FEAT_COMPONENT 1000)
cast the feature to ProAsmcomp and use ProAsmcompMdlMdlnameGet to get the name of the component and compare the name with the name of the model (ProMdlNameGet)
