May 18, 2015 10:43 AM UTC
How add costume node into model Tree with PTC Object Toolkit ?
can anybody give me some advice about model tree ?
gkochAnswer
2-Explorer
Jun 3, 2015 4:20 PM UTC
Do I understand correctly, that you want to insert additional customized lines into the model tree?
This should not be possible, as the tree reflects the model structure. Of course by adding features/items you will add lines as well.
Or are you aiming at adding columns?
Gunter
gkoch2-ExplorerAnswer
2-Explorer
Gunter
amedina-21-VisitorAuthor
Jun 4, 2015 7:10 AM UTC
Yes, you understand correctly, I want to insert additional customized lines, thanks for answer.
