18-Opal
May 24, 2018 6:59 AM UTC
How can I change the Material and Units
Hello
How can I specify the material and unit of the model?
2-Explorer
May 26, 2018 3:28 AM UTC
status = ProMaterialfileRead((ProPart)mdl,matl_name);
matl_name should be name of material file...Not the path of material file...
You can traverse to material directory by changing directory using API ProDirectoryChange() .After setting material, you can reset directory as earlier working directory.
2-Explorer
May 24, 2018 5:58 PM UTC
There is direct API for material and units.. Are you looking for API itself or you have some specific concern or issue for this functionality?
CHASEONHO18-OpalAuthor
18-Opal
May 25, 2018 12:08 AM UTC
What APIs do they perform?
Can you find information on related examples?
It is difficult to search in the API itself and to use the API in which functions.
It is difficult to be sure that the API is the feature I'm looking for, but it does search using protkdoc's html.
thank
2-Explorer
May 25, 2018 5:01 AM UTC
Give a try for below :
1. For Material : protkdoc/samples/UgMaterial_c.html#anchor-29
2. For Unit : /protkdoc/samples/UgMaterial_c.html#anchor-29
HIH
-Ketan
