Nov 18, 2015 3:46 PM UTC
how can I get vertices, faces and color of the part or assembly parts
Hello! Could you please tell me how can I get vertices, faces and colors oof the part or assembly parts in Pro/E Wildfire 4.0 using Pro/Toolkit (c++).
2-Explorer
Dec 4, 2015 6:06 PM UTC
Hello Vladimir,
how to do it, is nothing to explain in a few words in a thread.
I can just say that it is possible by accessing the geometry data of the model and that there are some examples about how to access that.
With colors you need to be aware that there are several levels of coloring possible for each surface (part surface color, model color and color assigned in assembly), so it depends whether you want to get the color currently showing or an underlying color.
Gunter
vvladimir1-VisitorAuthor
Dec 7, 2015 4:00 PM UTC
Hello Gunter,
It is quite clear. I do not want you to repeat chapters of user manual. However, could you please give me any clue/hint where to find.
Vladimir
2-Explorer
Dec 7, 2015 5:10 PM UTC
Hello Vladimir,
I would start with the section "Visiting Solid Geometry" under the chapter "Core: 3D Geometry".
It explains in short, how to traverse down to the geometry items for vertices and faces.
ProSolidSurfaceVisit() and/or ProSolidQuiltVisit() are probably functions you will need at the top of traversing.
To get the colors of surfaces, I would use ProSurfaceAppearancepropsGet()
There are useful links from the function descriptions to User's Guide and sample code.
Gunter
