How can i tell in my java program if a Dimension2D in a Drawing is a Basic dimension?
If I use the Properties UI to set a dimension2D as a Basic dimension how then can I find this Basic Dimension2D using the jlink API?
As an example, if a Dimension2D is set to be a Reference dimension then i can use the Dimension2D.GetIsReference() method to find Reference dimension.
I can not find an equivalent function for Basic dimensions, but i can imagine that i am not looking for it properly.
Any suggestions?
Tnx in advance!
johnu
Tnx!
johnu
Any suggestions?
Tnx in advance!
johnu
Tnx!
johnu
please ask PTC Support.
Hello Martin;
Thankyou for your reply, can you elaborate as to why i would need to go to PTC support for this topic?
Tnx!
johnu
@JohnU-PNSR wrote:
Hello Martin;
Tnx!
johnu
... because PTC Support engineer can answer your question.
