Mar 2, 2021 7:12 AM UTC
How do I connect from Creo to Windchill via the JAVA API?
Hello, please tell me how to use the JAVA API to connect to Windchill?
Mar 3, 2021 10:45 AM UTC
See windchill connection API in documentation located in Common Files/otk_java_doc/otk_javaug.pdf
or you can execute macro from jlink as normal macro using BaseSession.RunMacro() method
