How do I get a BOM / component list in java?
Hello, I'm trying to access the BOM or component list of an assembly so that I can use it in an import tool for another program.
I see in the otkjavaexamples a ListDisplayedComponents method that returns a list of parts, but I would also need the quantity. Also, this method seems to drill into the BOM structure. I just need the top level assembly parts and their quantities.
I can't seem to find the correct methods or classes to achieve this.
18-Opal
Well... there you go ... I love it when a long term plan comes together.. 🙂
Good Luck - I think you will find CREOSON pretty neat beyond the BOM data.
Dave
18-Opal
This requires quite a few steps to get via Java.... we optimized this in CREOSON (open source automation for Creo) to make it easier...  You can call it (amongst other functions ) from Java (or any other language) using JSON transactions via HTTP requests.
Look at the help doc for "bom : get_paths  top_level = true"
The JSON response from that you can then process for the quantities with a simple loop.
Alternatively, if you are looking for a more simple tool/way to get data into Excel for comparing/passing to another system.. Nitro-BOM works really well... (note we sell that)
Hope that helps.
Dave
abasRyan1-VisitorAuthor
I'll give this a read.
I need to upload the parts to another program via JSON and REST anyway.
Thnaks!
18-Opal
Dave
