18-Opal
Jun 18, 2018 6:07 AM UTC
How do I get the feature ID?
I tried to get the ID of the feature as follows:
status = ProSelect ("prt_or_asm", 1, NULL, NULL, NULL, NULL, & proselect, & selectcount);
status = ProSelectionModelitemGet (proselect [0], & mdlitem);
feat_id = mdlitem.id
However, mdlitem.id returns an infinitely large number.(ex. 5185215)
How do I get the feature ID of a tree column?
2-Explorer
Jun 18, 2018 10:59 AM UTC
Try using API ProSelectionAsmcomppathGet() after getting selection object.
This API would give you object  ProAsmcomppath. This contains comp_id_table and table_num. comp_id_table has number of entries equal to table_num. Last entry into comp_id_table is nothing but feature ID for your selected component.
HIH
Ketan
CHASEONHO18-OpalAuthor
18-Opal
Jun 18, 2018 8:36 AM UTC
Here are the reasons I raised this question.
Use ProAsmcompAssemble and ProAsmcompConstrRedefUI to assemble the model into the toolkit.
If you select Cancel in ProAsmcompConstrRedefUI to return PRO_TK_USER_ABORT, you must delete the component that was used when assembling.
You wanted to delete the feature with ProFeatureDelete.
All features ID were obtained using ProSolidFeatstatusGet.
We deleted the most recent feature ID (the one with the highest number).
So when I use ProSolidFeatstatusGet and ProFeatureDelete to cancel component placement, it removes the components used in that assembly.
2-Explorer
Jun 18, 2018 11:04 AM UTC
Why cant you try directly with ProFeatureDelete with handle you have with you for proasmcomp?
I guess it should allow as profeature and proasmcomp path is having same data structure of promodelitem.
I am not sure on this behaviour. If you are going to test this, please share your results.
-Ketan
2-Explorer
HIH
Ketan
18-Opal
Jun 19, 2018 1:07 AM UTC
ProFeatureDelete was performed with reference to the id of the ProAsmcomp object returned by ProAsmcompAssemble.
The results are very successful.
