Apr 24, 2013 2:56 PM UTC
how do we connect to creo parametric 2.0 using j-link API.
Hi all ,
How do i connect to creo parametric 2.0 using j-link.
and what are the configurations/variables i have to set.please help.Thanks in advance
7-Bedrock
Apr 25, 2013 8:49 AM UTC
Have you read the manual already (jlinkug.pdf - 1. Setting up Jlink)? Should be located in the '\Common Files\...\Jlink\' folder of your creo installation directory.
pshetty-21-VisitorAuthor
Apr 25, 2013 9:27 AM UTC
Yes i have gone through jlinkug.pdf.
Facing some error while creating the Proe Connection through the method AsyncConnection_Start . The error that i am getting is ‘com.ptc.pfc.Implementation.pfcExceptions$XToolkitGeneralError’.I am setting the environment variables PRO_COMM_MSG_EXE and PRO_DIRECTORY.One doubt I had was that where PRO_DIRECTORY variable should be set, I am setting it to ‘C:\PTC\Creo\creo2_m040_x86\CommonFiles’ . What are the other things that we need to take care to connect to Creo Parametric 2.0 MO40?
7-Bedrock
Apr 25, 2013 11:46 AM UTC
I have PRO_DIRECTORY set to C:\ptc\Creo 1.0. Works fine...
btw, 'pfcasync' should also be added to Classpath but I presume you already did that.
