7-Bedrock
Jul 22, 2019 9:21 AM UTC
How to Activate Dialog Help Button
There is an dialog attribute (.HelpButton) in source file which can be set to true.
But the help button is always gray out.
Does anyone know how to activate and set action for the help button in toolkit/object toolkit?
Dec 4, 2019 2:53 PM UTC
Hi
You need to use OTK.
// Header
 class helplistener : public uifcDefaultDialogListener {
public:
void OnHelp(uifcDialog_ptr dialog);
void OnClose(uifcDialog_ptr dialog);
// Code
uifcDialogFind(DIALOG_NAME, DIALOG_NAME)->AddActionListener(new helplistener());
uifcDialogFind(DIALOG_NAME, DIALOG_NAME)->SetHasHelpButton(true);
void helplistener::OnHelp(uifcDialog_ptr dialog)
  // do what ever you like
If there is no OnHelp Action is the same as if there is no OnClose Action. The Buttons are disabled.
The onHelp Action doesn't override the F1 Button Help Call.
Br,
Eike
18-Opal
Sep 25, 2019 6:49 AM UTC
Did you solved?
if so, Can you please tell me how to activate Dialog Help Button..
Hi
// Header
public:
// Code
Br,
Eike
18-Opal
Dec 5, 2019 7:23 AM UTC
@Eike_Hauptmann ,
Could you please tell me how to apply in C/C++ object toolkit?
Warm Regards,
SeonHo CHA
