11-Garnet
How to add a parameter in repeat region?
In our drawings we need to add the customized balloon that should call the parameter "Findo". Can you all please help me to get a solution?
RPN
RPNAnswer
18-Opal
The find number is a component/feature parameter. Just get all components and create the required parameter for this feature and assign the value you want. For Windchill the parameter should be designated.
RPN
RPN18-OpalAnswer
18-Opal
Thanus_MR11-GarnetAuthor
11-Garnet
I added the parameter in repeat region table, now I want to call that Find no string in balloon, I'm not getting how to customize the balloon
RPN
18-Opal
You must tell the tool which column to use for display. Check the menu options.
