6-Contributor
How to add text below drawing dimension?
I am not able to set Text below drawing dimension,  If any one has solutions please suggest.
Hi, you might check out the following API: ProDimensionTextWstringsSet
The docu provides an example:
err = ProArrayAlloc (0, sizeof(wchar_t*), 1, (ProArray*)&p_texts);
 while(1)
 err = ProMessageStringRead (127, buffer);
			if(err != PRO_TK_NO_ERROR)
				break;
			err = ProArrayObjectAdd ((ProArray*)&p_texts, PRO_VALUE_UNUSED, 1,&buffer);
			err = ProWstringLengthGet(buffer,&wstrLen);
			err = ProArrayAlloc (wstrLen+1, sizeof(wchar_t), 1, (ProArray*)&p_texts[arrIndex]);
			ProWstringCopy(buffer,p_texts[arrIndex],PRO_VALUE_UNUSED);
			arrIndex++;
 err = ProDimensionTextWstringsSet (dim, p_texts);
 TEST_CALL_REPORT("ProDimensionTextWstringsSet()",
 "ProTestDimensionEdit()", err, err != PRO_TK_NO_ERROR);
		for(ii=0;ii<arrIndex;ii++)
			err = ProArrayFree ((ProArray*)&p_texts[ii]);
 err = ProArrayFree ((ProArray*)&p_texts);
