Feb 5, 2020 5:20 AM UTC
How to call a external applications using OS script (mapkey)?
Dears,
Can anyone help to understand how to call a external applications using OS script (mapkey)?
For example if I want to open https://community.ptc.com/  using a OS Script (mapkey) how can I do this.
Does it require VBA coding?
Sreenivas
Feb 5, 2020 1:26 PM UTC
OS Skript (inside Mapkey Editor):
start "" "http://www.inneo.de"
is saved as :
 @SYSTEM start http://www.inneo.com;
inside the config.pro.
Br,
Eike
Feb 5, 2020 8:40 AM UTC
Hi ...
you can use following Mapkey
e.g.
Br,
Eike
Feb 5, 2020 8:52 AM UTC
Hello Eike,
Thank you very much for your response.
I just simply copy pasted
in the OS script. But its not working. Am I missing something here
Sreenivas
is saved as :
Br,
Eike
Feb 5, 2020 4:03 PM UTC
I use it to open my working directory and open external programs also.
here is one example:
@echo off
set cdn=%cd%
set cust=%cdn:~10,3%
set trcn=%cdn:~13,9%
if exist "\\your server\Customers\%cust%\_Final Docs\%trcn% docs" (
start "" "\\your server\Customers\%cust%\_Final Docs\%trcn% docs"
if exist "\\your server\CUI\ITAR\%cust%\_Final Docs\%trcn% docs" (
start "" "\\your server\CUI\ITAR\%cust%\_Final Docs\%trcn% docs"
Feb 6, 2020 6:07 AM UTC
@echo off
set cdn=%cd%
my suggestion ...
1.] create batch file, eg. myapp.bat and put following commands into it
@echo off
set cdn=%cd%
2.] during mapkey creation put following info into OS Script tab area
start "window title" /D working_directory_path path_to_batch_file
Note: The above mentioned start command is just my guess, only.
