How to change default sketching tool properties?
I'm trying to change the Text tool in the sketcher so that a certain font and alignment is used every time. I can create a mapkey, but if I continue to make a second text item the settings go back to the default. Is there a way to change this? I didn't see any options in the config editor.
I am almost sure that requested functionality is not implemented OOTB.
