Mar 25, 2024 12:20 PM UTC
How to change PART model with Excel VBA
1. Define the dimension name of the PART model in uppercase English letters.
 2. program execution code
     [Please refer to the attached file for Excel VBA code.]
Dim BaseSession As pfcls.IpfcBaseSession
Dim Session As IpfcSession
Dim model As pfcls.IpfcModel
Dim Solid As IpfcSolid
Dim ModelItemOwner As IpfcModelItemOwner
'// Current Model Information
Set BaseSession = conn.Session
Set model = BaseSession.CurrentModel
Set Solid = model
Set ModelItemOwner = Solid
'// SET Regenerate
Dim RegenInstructions As New CCpfcRegenInstructions
Dim Instrs As IpfcRegenInstructions
Set Instrs = RegenInstructions.Create(False, False, Nothing)
Dim BaseDimension As IpfcBaseDimension
Dim j As Long
For j = 0 To rng.Count - 1
Set BaseDimension = ModelItemOwner.GetItemByName(EpfcModelItemType.EpfcITEM_DIMENSION, Cells(j + 6, "B"))
'// Send entered dimension values to model
BaseDimension.DimValue = Cells(j + 6, "C")
Next j
'// Regenerate
Call Solid.Regenerate(Instrs)
'// Window Repaint
Dim Window As pfcls.IpfcWindow
Set Window = BaseSession.CurrentWindow
Window.Repaint
conn.Disconnect (2)
How to use the program
1. Change the name of a dimension in a model.
    . Example) ADD375 -> DOM01
2. Enter the name of the dimension in your model under Cells(6,B).
    .Three or more sizes are also possible.
3. Click the GET button
    . Retrieves dimension values from model
4. Click the Change button
    . Change the dimension value and click the change button
