Apr 16, 2024 7:38 AM UTC
How to cleanup the Dimensions in Drawing using VB API
Hello Everyone, I am facing a problem with 'Dimension Cleanup' in drawing using the VB API.
I am fetching dimensions from the 3D Model and placing them in the drawing using the VB API. However, these dimensions are placed in random positions on the drawing, so I need to clean them up and move them to the correct positions for the particular view.
Please share if you have any ideas.
Emeritus
Apr 19, 2024 8:43 AM UTC
Hi @SN_10505026
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
