Sep 3, 2012 12:04 PM UTC
How-to construct a ComponentPath with VB API
From an Excel macro, I tried to create a ComponentPath with the VB API method
CMpfcAssembly.CreateComponentPath(topassy, sequence)
The sequence should be a sequence of Integers (according to API docs)
But I get an error when trying to construct an object of type Cintseq:
Dim sequence As Cintseq
Msgbox (CStr(sequence.Count))
The last line throws a Run-time error '48' - Error in loading DLL
In debug mode, the locals window in VBA shows that the 'sequence' is still set to Nothing instead of a valid object.
The VB API seems to be registered correctly, though, since I can connect to Creo and perform other manipulations on Creo objects.
And the Object Browser in VBA lists the Cintseq class correctly.
Anyone who can help me out on this ?
