How to create a pcf file with toolkit
Hello, I have a question while I was making a function related to printing in creo toolkit.
We confirmed that the function has a ProPrintPCFOptionsGet that uses the pct file to retrieve the print settings. I think it's a very useful feature, but I thought I had to have a pcf file before I could use it.
So I tried to create a function to create a pcf file first, but I couldn't see the proper function, so I had a hard time.
Can you recommend a function that makes a pcf file? Or if you know how to make a function without using it, I'd appreciate it if you could let me know.
Thank you.
Another options:
1. Create this file as text file
2. Maybe, it is possible to save it from Creo by running a mapkey from toolkit
pcf file cannot be created by Toolkit. You can save it from Creo session.
Another options:
