Jan 26, 2015 8:27 PM UTC
How to create construction lines in a section?
Hi all,
I am trying to create construction lines in a section that is to be displayed in a sketch in my Creo model. Looking at the API, there appears only methods for setting the endpoints of the line using a pfcOutline_ptr object. Is there another class that these sectionEntities inherit from that determines their display styles?
Thanks in advance,
Dan
Feb 17, 2015 7:27 PM UTC
Is the sketch in a 2D drawing? or 3D model?
I'm not sure about in OTK, but in the original toolkit, I think you can do this via ProDtlentitydataConstructionSet for a 2D drawing. For a 3D sketch/section, you may have to go into the feature element tree... but I'm not quite sure.
dstaves1-VisitorAuthor
Mar 10, 2015 7:02 PM UTC
Thank you for your response James!
It seems that the function required to determine the construction status of a section curve is not yet implemented in OTK. I was able to use pro/toolkit to implement your suggestion.
Thanks again,
Dan
