Dec 9, 2016 7:22 AM UTC
How to create proselection object programatically?
I am trying to select 3D point this way.
    TomasLounAnswer
    Dec 12, 2016 8:58 AM UTC
    In Pro/Toolkit you can use ProSelectionAlloc. The second parameter is Promodelitem - your 3D point.
    Dec 9, 2016 1:18 PM UTC
    Which language / API ?
    lgangwar1-VisitorAuthor
    Dec 12, 2016 5:25 AM UTC
    I want to use PROTK API for making this happen. It is based on C language structure.
    TomasLoun1-VisitorAnswer
    Dec 12, 2016 10:17 AM UTC
    I want to use ProNoteAttachAddend() API for making leader line to my note. For this Proselection object is required. I am able to create ProSelection object but not able to set selected id and type correctly to my proselection object.
    Dec 12, 2016 9:02 AM UTC
    ProSelction object can be created by using the item name and item type.
    Make ProModelItem object first (using 'ProModelitemByNameInit'), and then create ProSelection object (using 'ProSelectionAlloc').
    Dec 12, 2016 1:49 PM UTC
    I am making a point programatically (so don't have name or id of this point) and select it as a proselection() object programatically.
    Dec 12, 2016 2:03 PM UTC
    How do you create the point programmatically? Could you post here a piece of code? It should be a modelitem, so you should be able to use it directly in ProSelectionAlloc..
    Dec 14, 2016 6:36 AM UTC
    All suggested methods are good and to the point. But in my case i got one API ProGeometryAtPointFind() works really well. This API should be used when you are certain that your 3D point will be on the part surface somewhere.
    Dec 14, 2016 1:16 PM UTC
    This method will tell you surfaces or edges where the point lays on. I probably do not understand what are you exactly going to do...
    Dec 15, 2016 5:11 AM UTC
    See i need model item to fill proselection object and i already know that the co-ordinates which i have they are on part. So by using this API "ProGeometryAtPointFind" i get the proselection object at that point directly. It creates proselection object on that part with appropriate data structure.
    extern ProError ProGeometryAtPointFind ( ProPart part,
                                 Pro3dPnt point,
                                 ProSelection** p_sel_arr,
                                 int* p_count);
       Purpose:     Determines the surfaces or edges on which the specified
                    point is located.  If a point lies on an edge, the function
                    does not return the neighboring surfaces.
       Input Arguments:
          part      -  The part handle.
          point     -  A three-dimensional point, in the coordinates of the part.
       Output Arguments:
          p_sel_arr - An array of <I>ProSelection</I>, which has information
                      about surfaces or edges on which the point is located.
                      The function allocates space for this array; free it
              using ProSelectionarrayFree().
          p_count   - The number of items on which the point lies.
      Return Values:
          PRO_TK_NO_ERROR    - The function successfully evaluated the point.
          PRO_TK_BAD_INPUTS  - One or more of the input arguments are invalid.
          PRO_TK_E_NOT_FOUND - The surface or edge was not found.
