May 9, 2017 5:31 AM UTC
how to create text folder in protoolkit
tell the some example
May 10, 2017 7:21 PM UTC
Hi Keerthana,
Tthe "text" folder can actually be created almost anywhere on your machine.
  1. First, you must build your code into the desired DLL or EXE
  2. Next, create a "protk.dat" file, which you can "register" into Creo.
  3. That "protk.dat" file points Creo to the location of the "text" directory that you would like to load with your application.
You should be able to mimic the setup of the examples. For Pro/TOOLKIT, check out the "protk_install_example" that is located in the "protoolkit" subfolder of your installation.
Here are some PTC support docs that may also help:
If you need help with this, feel free to send me a PM. I'd be happy to try to help.
James Sullivan
CadActive Technologies
