11-Garnet
May 15, 2026 10:42 AM UTC
How to delete the system generated notes through toolkit?
Hi everyone,
Does anyone knows how to delete or remove the system generated notes.
I tired the APIs,
ProDtlnoteRemove() - failing
ProDtlnoteDelete()  - failing
ProDtlnoteErase() - erasing note until next regeneration
these above API are removing all the notes except the system generated note (for eg: scale 1:1, section x-x).
11-Garnet
May 22, 2026 4:03 AM UTC
Hey, I got the solution, thanks for the reply
the system generated notes like SECTION X-X or DETAIL A can be deleted using ProNoteDelete(), we just need to bring them in ProNote datatype
May 22, 2026 3:50 AM UTC
This kind of notes cannot be deleted, you may check this article.
https://www.ptc.com/en/support/article/CS163560
VP_1444068911-GarnetAuthorAnswer
11-Garnet
