May 12, 2017 9:57 AM UTC
How to display current model name in popup dialog
Anybody explain me.I am  a beginner in protoolkit
May 12, 2017 1:47 PM UTC
I can only give you an exmple in J-link:
Session session = pfcGlobal.GetProESession();
Model model = session.GetCurrentModel();
String modelName = model.GetFullName();
session.UIShowMessageDialog(modelName, null);    // this brings default Creo ui dialog with name of current model
kguru1-VisitorAuthor
May 16, 2017 11:04 AM UTC
Thanks.I need protoolkit coding
May 17, 2017 5:57 PM UTC
I do something similiar what your asking. ParamValString is a function I have that gets the parameter value for a string param.
Basically I print my info to a text file, then open the text file using ProInfoWindowDisplay.
You could use ProUIDialog functionality as well for a fancier method.  I just found this method very simple to do.
strcpy(mypar, ParamValString("NAME", modelitem));
fprintf(fp," Parameter information for %s\n",mypar);
fprintf(fp,"------------------------------------------------------------------\n");
fprintf(fp," DESCRIPTION: %s\n",ParamValString("DESCRIPTION", modelitem));
fprintf(fp," NAME: %s\n",ParamValString("NAME", modelitem));
fprintf(fp," MATERIAL: %s\n",ParamValString("MATERIAL", modelitem));
fprintf(fp," UNIT_OF_MEASURE: %s\n",ParamValString("UNIT_OF_MEASURE", modelitem));
  ProStringToWstring (wfname, "c:\\temp\\ViewPars.txt");
  status = ProInfoWindowDisplay (wfname, NULL, NULL);
May 18, 2017 5:14 AM UTC
Hi Keerthana,
I posted this a few days ago - it may help: Re: create popup menu with button clik
Mark's code is definitely useful ( I actually am a huge fan of the ProInfoWindowDisplay ), but without having the custom "ParamValString" method, here's another method that may work for you:
ProError creoTest() {
    ProError err = PRO_TK_NO_ERROR;
    ProMdl current_model;
    ProMdlName current_model_name;
    err = ProMdlCurrentGet(&current_model);
    if (err != PRO_TK_NO_ERROR) { return err; } // in case you don't have a model open
    err = ProMdlMdlnameGet(current_model, current_model_name);
    ProUIMessageButton *buttons; // an array of buttons
    ProUIMessageButton ok_button = PRO_UI_MESSAGE_OK;
    ProUIMessageButton cancel_button = PRO_UI_MESSAGE_CANCEL;
    err = ProArrayAlloc(0, sizeof(ProUIMessageButton), 1, (ProArray*)&buttons);
    err = ProArrayObjectAdd((ProArray*)&buttons, -1, 1, &ok_button);
    err = ProArrayObjectAdd((ProArray*)&buttons, -1, 1, &cancel_button);
    ProUIMessageType message_type = PROUIMESSAGE_INFO;
    ProUIMessageButton user_picked_this_one = PRO_UI_MESSAGE_CANCEL; // set an initial value just in case
    err = ProUIMessageDialogDisplay(message_type, L"Current Model Name", current_model_name, buttons, ok_button, &user_picked_this_one);
    if (err == PRO_TK_NO_ERROR && user_picked_this_one == PRO_UI_MESSAGE_OK) {
      return PRO_TK_NO_ERROR; // hooray! ^_^
    return PRO_TK_USER_ABORT;
NOTE: If you are using Creo 2 - then you will need to use "ProName" instead of "ProMdlName", and "ProMdlNameGet" instead of "ProMdlMdlnameGet".
James Sullivan
CadActive Technologies
President & Founder
May 18, 2017 11:13 AM UTC
Thanks sir. Now It work.
