Apr 26, 2016 11:33 AM UTC
How to execute examples from object toolkit c++
Hi Guys!
I did install Creo Parametric3 and several toolkits.
Successfully built otk_install example(when I click the button on the Home bar - popup message appears).
Everything just fine till I get into examples:
I picked up this one: otk_examples_feat (...\PTC\Creo 3.0\M090\Common Files\otk\otk_cpp\otk_examples\otk_examples_feat)
file name: OTKXCreateSection3D.cxx
I made separate project. configured it, checked it - everything is ok with environment.
I built this example, launch Creo Parametric with it.
And now I'm stuck.
How to launch it in Creo Parametric? According to example description it should create some data in sketch. But how to initiate this process?
I cant find any appropriate button.
Thank you in advance,
Artem
abursuk1-VisitorAuthor
Apr 26, 2016 1:29 PM UTC
Hey,
I realized that these are not End2End examples.
I added custom button and initiate func from example using this button.
Everything is fine now.
Artem
Aug 3, 2018 11:33 AM UTC
I am very new in Creo Parametric.I am working on an application with help of proToolkit in C++.
Can you explain how to create project settings for successfully build.
