How to export a part or assembly to 3d pdf using vb API in creo 10
I'm using Creo 10 and i'm trying to export the model to 3d PDF using VB COM API in C#.
i tried below 2 options and getting exceptions.
 var instructions = new CCpfcPDFExportInstructions().Create();
 model.Export(pdfFilePath,(IpfcExportInstructions) instructions);
 model.ExportIntf3D(pdfFilePath, (int)EpfcExportType.EpfcEXPORT_PDF,null);
can you please provide some code sample to guide me through?
sahmedsAnswer
Solved it!.
 private IpfcPDFExportInstructions GetPDFInstructions3D(EpfcPDFExportMode expMode)
 var opts = new CpfcPDFOptions();
 var opt1 = new CCpfcPDFOption().Create();
 opt1.OptionType = EpfcPDFOptionType.EpfcPDFOPT_LAUNCH_VIEWER;
 opt1.set_OptionValue(new CMpfcArgument().CreateBoolArgValue(false));
 opts.Append(opt1);
 var opt2 = new CCpfcPDFOption().Create();
 opt2.OptionType = EpfcPDFOptionType.EpfcPDFOPT_EXPORT_MODE;
 opt2.set_OptionValue(new CMpfcArgument().CreateIntArgValue((int)expMode));
 opts.Append(opt2);
 var opt3 = new CCpfcPDFOption().Create();
 opt3.OptionType = EpfcPDFOptionType.EpfcPDFOPT_ORIENTATION;
 opt3.set_OptionValue(new CMpfcArgument().CreateIntArgValue((int)EpfcSheetOrientation.EpfcORIENT_LANDSCAPE));
 opts.Append(opt3);
 var opt5 = new CCpfcPDFOption().Create();
 opt5.OptionType = EpfcPDFOptionType.EpfcPDFOPT_VIEW_TO_EXPORT;
 opt5.set_OptionValue(new CMpfcArgument().CreateIntArgValue((int)EpfcPDFSelectedViewMode.EpfcPDF_VIEW_SELECT_CURRENT));
 opts.Append(opt5);
 instructions.set_Options(opts);
 return instructions;
sahmeds10-MarbleAuthorAnswer
Solved it!.
 opts.Append(opt1);
 opts.Append(opt2);
 opts.Append(opt3);
 opts.Append(opt5);
