Nov 30, 2020 1:40 PM UTC
How to extract Dimension Texts from a CREO drawing using VB API?
Iam able to extract text from symbols and detail notes by getting a handle of notes/symbol using the following code,
modelitems =  detailItemOwner.ListDetailItems(EpfcDetailType.EpfcDETAIL_NOTE, 1)
Now i need to extract Dimension Texts from a drawing.
the modeItems that are returning from the above code does not contain dimension texts
Any idea on how to extract those informations?
HanSolo97Answer
Dec 1, 2020 5:50 AM UTC
Found the solution myself
For anyone else having the same problem. here you go
For m = 0 To session.ListModels.Count - 1
model = session.ListModels.Item(m)
Dim ModType As Integer = model.Type
If model.Type = 1 Or model.Type = 0 Then
MIowner = CType(model, IpfcModelItemOwner)
MIs = MIowner.ListItems(EpfcModelItemType.EpfcITEM_DIMENSION)
For i = 0 To MIs.Count - 1
dimension = MIs.Item(i)
dimensions = dimension
shXL.Cells(J, 1) = dimensions.Symbol
shXL.Cells(J, 2) = dimensions.DimValue.ToString
shXL.Cells(J, 3) = model.FileName
Dim texts As Cstringseq = dimensions.Texts
For t = 0 To texts.Count - 1
str = str & texts.Item(t)
Next
shXL.Cells(J, 4) = str
J = J + 1
End Try
Next
End If
Next
HanSolo971-VisitorAuthorAnswer
Next
J = J + 1
End Try
Next
End If
Next
