Mar 25, 2024 11:07 AM UTC
How to fix rename.csv files which is generated by wbmff
I am using Creo 8.0.7.0 and extracting information for creo .asm, .prt files usinf wbmff.
wbmff generates the rename.csv file list basically these files get renamed over OS level not by using creo.
I have gone through the Article: https://www.ptc.com/en/support/article/CS212774?source=search
Is there any way to update the rename.csv listed Files using JLInk or some other tool.
Model opening properly in Creo for reported renamed files but when i extract the information using wbmff it reports files get renamed.
Is there any way to handle this scenario by some code or utility i have around 700 files reported in rename.csv.
Community Moderator
Apr 2, 2024 7:24 AM UTC
Hello @KU_10825185,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team
