How to get IsObjectCheckedOut ?
Hi there,
in the web.link "documentation" there is a function
boolean IsObjectCheckedOut (string WorkspaceName, string ObjectName)
within the "Class pfcServer"
I tried
let active_ws = oSession.ListServers().Item(0).ActiveWorkspace;
console.log (oSession.IsObjectCheckedOut(active_ws , CurModel.Filename));
But I only get "TypeError: oSession.IsObjectCheckedOut is not a function"
How do I get the information, if an object is already checked out?
This method is from IpfcServer not from Session object
IpfcServer.IsObjectCheckedOut()
Mat16-PearlAuthor
Thanks for Your reply.
Unfortunately, there is no "IpfcServer" Class in Web.Link. I guess, that there is a IpfcServer in VB - Toolkit.
The according Class in Web.Link is simple called "pfcServer".
That said, the solution is quite straight forward:
let active_server = oSession.ListServers().Item(0); //usually, there is only one Windchill - server registered
let active_workspace = active_server.ActiveWorkspace;
let FileName = EPMObject.FileName;
return active_server.IsObjectCheckedOut(active_workspace , FileName ); // returns "false" / "true"
Edit:
by the way, there was a typo in my original post.
There is no property "Filename" for "CurModel". It should have been "CurModel.FileName".
