2-Explorer
Sep 2, 2014 3:12 PM UTC
How to get model item instance details using VBAPI
I am very new to VBAPI.
I am facing issue to get details of symbol instances details used in drawing file.
I know that "ListDetailItems" is the API to use which require object of "IpfcDetailItemOwner".
I am not able to get "IpfcDetailItemOwner". PLease help me with the same.
Thanks in advance.
I can provide you the code snippet which gives me no result for output of API "ListDetailItems" if required.
Regards
Ketan
Sep 4, 2019 6:52 AM UTC
Did you get answer for above problem?
2-Explorer
Sep 5, 2019 4:51 AM UTC
I am not using VBAPI since so long. Actually, I can't recall also whether that issue got resolved or not.
