2-Explorer
Jan 6, 2021 2:27 PM UTC
how to get section arrow location using toolkit
Hi All
Is there any API introduced / already available to check location of section arrow in drawing? We just want to confirm whether any arrow is going outside of border or not. We have Creo 4.0 M130.
Attached image is for reference of arrow going outside of border.
Jan 6, 2021 3:20 PM UTC
This is not part of Creo Toolkit functionalities. It is documented with article CS217909
File an enhancement request if required.
FV_01
Jan 8, 2021 5:31 PM UTC
@Ketan_Lalcheta wrote:
Hi All
Hello all,
  • from Pro/Toolkit get a view outline.
  • output a drawing sheet to a DXF.
  • extract section lines, arrows, text data from DXF. Lines will have the same LTYPE and LAYER and geometry will match parallel | parallel | perpendicular pattern with the end point of the first line 'double' equal to the start point of the next line and so on... Arrows will also have end points matching 'short' line end points.
  • calculate an enclosing box, get the center point.
  • check calculated center point with view outline - IN/OUT
  • delete DXF file.
HIH.
FV.
