Nov 19, 2015 9:57 AM UTC
How to get the item under the cursor after a mouse click
I am coding a tool with ProToolKit,
it's as follows,
1, the user click the left mouse button the the drawing.
2, If there is a note or a dim at the mouse cursor, then change the color of the note or dim to Red.
3, if there is a geometry (surf or line) at the mouse cursor, then change the geometry color to Green.
4, if there is nothing at the cursor when clicking, do nothing.
I can use ProMousePickGet()  to  read the screen coordinate of the mouse,
But , how to find whether there is a note or a geometry at the cursor?
Is there a API method ?
Please help.
FV_01
FV_01Answer
Nov 25, 2015 2:11 PM UTC
Hi all,
The examples of pre or post filters are in 'TestFamTab.c'.
The short version:
static ProError test_sel_psf( ProSelection selection, ProAppData app_data)
ProError err = PRO_TK_NO_ERROR;
ProGeomitem    gi;
err = ProSelectionModelitemGet( selection, (ProModelitem *) &gi);
if( err != PRO_TK_NO_ERROR ){
  return( PRO_TK_NO_ERROR);
ProWindowRepaint(PRO_VALUE_UNUSED); // in real life situation - would have to use ProSelectionUnhighlight() for previously highlighted entities
if( gi.type == PRO_CURVE || gi.type == PRO_EDGE || gi.type == PRO_SURFACE){
  ProSelectionHighlight( selection, PRO_COLOR_SHEETMETAL); // green
else {
  ProSelectionHighlight( selection, PRO_COLOR_ERROR); // red
ProError test ()
ProError err = PRO_TK_GENERAL_ERROR;
int n_sel = 0;
ProSelection *p_sel = NULL;
ProSelFunctions      sel_functions;
memset( &sel_functions, '\0', sizeof( sel_functions));
  sel_functions.pre_filter = NULL;
  sel_functions.post_filter = test_sel_psf;
  sel_functions.post_selact = NULL;
  sel_functions.app_data = NULL;
  err = ProSelect( "any_note,symbol_3d,sldedge,dimension", 1, NULL, &sel_functions, NULL, NULL, &p_sel, &n_sel);
  if( err != PRO_TK_NO_ERROR) {
   return( PRO_TK_GENERAL_ERROR);
  else if( n_sel <= 0 )
// do something with selection
HIH.
Feliks.
Nov 19, 2015 7:10 PM UTC
Hi -
ProMousePickGet will only provide you with coordinate values. If you want to select entities, you'll need to use ProSelect.  ProSelect, and the ProSelection data structure it returns, can be used in many ways. Give yourself some time to learn it.
Here's a summary of some code I wrote a long time ago to select a single drawing note:
ProSelection *selection ;     // Pro/Array of entity selection data
int           selection_cnt ; // Size of selection[]
ProError      error ;         // Pro/Tk error value
error = ProSelect( "any_note", 1, NULL, NULL, NULL, NULL, &selection, &selection_cnt ) ;
You'll need to add code to check the returned error value.
|+|  M a r k  |+|
xd_011-VisitorAuthor
Nov 20, 2015 1:19 AM UTC
Hi Mark, thanks for your reply.
I knew about the ProSelect function,
Using ProSelect function, we must indicate the parameter "any_note".
Then, it can not return from the ProSelect function with a left button click and nothing is selected,
it return until 1 note item is selected or the select dialog is canceled.
Actually,What i need is only one click and then something is done.
It can not be trapped in the ProSelect function.
In my opinion, i want to use ProMousePick to get a left button click, and then check if there is a note or geometry.
But i do not know how to check it.
And i believe it's useful to find out if there is a item (dim, note or geometry) at the indicated point.
Is there any suggestion?
Nov 20, 2015 9:21 AM UTC
Well, Mark's answer is the only way to do it in a good and safe way.
...however, you could build an asynchronous application that listens to Mouse events. Every time there is a click, get the current selection buffer, look inside it, see if there is something selected that you want to work with and then do that.
I would not recommend doing it this way, though, as the Creo selection buffers are notoriously fickle. And I'd really, REALLY not recommend doing it with the TK, since it hasn't got error handling and will crash your asynch application (and, if you're unlucky, Creo as well) when there's something wrong with the selection buffer.
EDIT: Just looked it up in the API and this will likely not even work as ProSelbufferSelectionsGet needs an active selection buffer and thus likely needs a running selection tool to even exist.
Nov 23, 2015 12:05 AM UTC
Thanks everyone, though not solved.
FV_01
Nov 23, 2015 8:36 PM UTC
XD,
Prefilter will work for geomitems only - notes out of the question... I did not realize it. Please use postfilter - take a look at the attached video. Unfortunately there is a slight delay between placing a cursor over the entity and color change event - looks like unavoidable...
HIH.
Feliks.
Video Link : 6535
Nov 25, 2015 4:33 AM UTC
hi Feliks, thanks for your reply. But, i can not see the video. will you send the video to xd200800@163.com?
And will you show me the post filter usage?
