How to get the ProGtolPlacementType from ProGtolAttachGet()
ProGtoldataPlacementGet is deprecated in Creo 9 and it says that it was superseded by ProGtolAttachGet. One of the fields that ProGtoldataPlacementGet would retrieve is the ProGtolPlacementType which is the field that I need. Is there another way to get the ProGtolPlacementType, or do I have to convert the switch cases I have over to the ProGtolAttachType instead?
Mark
