Oct 17, 2015 12:12 PM UTC
How to Hide Datum Planes,Points,Curves,etc.. into Layer using ProToolKit API? Please suggest any work around to hide uncontrolled datums into Layer.
Hide datum’s, axis,points,etc into layers which is not controlled thru layer command.
2-Explorer
Oct 19, 2015 4:36 AM UTC
I have not tried implementation but you can give a try below API:
  • ProLayerItemsGet
  • ProModelitemHide
Thanks and Regards
Ketan
Oct 27, 2015 1:01 PM UTC
Please find a piece of code I'm using
  // Declarations
ProLine w_old_axis_display;
// Backup current display mode (here for axis only)
ProConfigoptGet(L"axis_display", w_old_axis_display);
// Set your mode
ProConfigoptSet(L"axis_display", L"yes");
// Do what you want
FV_01
Oct 30, 2015 3:00 PM UTC
Hi all,
Nikhill, take a look at TestLayer.c in pt_examples directory.
HIH.
Feliks.
