Aug 21, 2013 4:42 AM UTC
How to identify the CSYS used in the Model thru J-Link
I'm able to successfully list all the CSYS available in the Model using the J-Link API "Model.ListItems(ModelItemType.ITEM_COORD_SYS)".
But I'm unable to identify the CSYS used in the Model thru J-Link. Any leads on this is greatly appreciated.
Regards
Murari
Aug 21, 2013 11:07 AM UTC
Murari,
One way to do it is through interactive selection. Here is a section copied from the API wizard.
Select a coordinate system. This defines the model (the top one
in that view), and the common attachments for the dimensions
Session session = pfcGlobal.GetProESession ();
SelectionOptions selOptions =
pfcSelect.SelectionOptions_Create("csys");
selOptions.SetMaxNumSels (new Integer (1));
Selections selections = session.Select (selOptions, null);
if (selections == null || selections.getarraysize() == 0)
return;
Extract the csys handle, and assembly path, and view handle.
Selection csysSel = selections.get (0);
ModelItem selItem = csysSel.GetSelItem();
ComponentPath selPath = csysSel.GetPath();
View2D selView = csysSel.GetSelView2D();
Point3D selPos = csysSel.GetPoint();
if (selView == null)
throw new RuntimeException ("Must select coordinate system from a
drawing view.");
Model2D drawing = (Model2D)selView.GetDBParent();
Jim
Aug 21, 2013 11:33 AM UTC
Hello Jim,
Thanks for responding. Unfortunately, the requirement is to run this utility non-interactively on the 3D Model.
Please let me know if there are any work-around's to achieve this. I did not come across the relevant API but not sure if I'm missing anything here.
Regards
Murari
Aug 21, 2013 11:37 AM UTC
Murari,
Actually, I have this exact same issue facing me at the moment. I am kind of hoping someone can help us out. If I find a solution, I will post it.
Jim
