Jun 13, 2015 1:19 PM UTC
How to insert cgm file inside a drawing?
I need insert a cgm file inside a drawing .... using VB Api...
Jun 15, 2015 7:19 PM UTC
Vaduga,
Not sure if this would work
Could you create a trail file while doing the process manually for each drawing size and then minipulate the trail file with the VB API then call the trail file to place the cgm file in the drawing?
Don Anderson
