Apr 25, 2018 7:20 PM UTC
How to insert UDF with jlink
Hello
I need some guidance on how to install an UDF into a part.
I have the UDF into a file. I cant seem to set the name of the UDF file to the object of type UDFCustomCreateInstructions.
Which is the command that should indicate which UDF should be inserted?
Secondly, I have the axis and plane datums that should be set as references and I am not sure which is the correct way to set the references.
Any suggestion or example is welcome.
Thank you
Regards
HamsterNL
18-Opal
Apr 26, 2018 3:13 PM UTC
There are multiple examples in the jlinkug which should be available to you in your install directory of Creo.
Anyway, your UDFCustomCreateInstructions should look something like this:
UDFCustomCreateInstructions instrs = pfcUDFCreate.UDFCustomCreateInstructions_Create ("hole_quadrant");
vjoer1-VisitorAuthor
Apr 26, 2018 7:33 PM UTC
Hello
Thank you for your aswer.
I am aware of the example in the install directory. And still I havent found all the info I need.
For example, in your call, the "hole_quadrant" is the name of the UDF file? How do I specify a full path to the UDF file?
Regards
HamsterNL
18-Opal
Apr 28, 2018 5:36 AM UTC
A UDF is either in the current directory, or you could have a UDF Library (specify the directory with the configuration file option "pro_group_dir".
About Creating a UDF Library
